I'm trying to load a map package, i.e load every layer contained in the map package (mpk file). This map package is in a shared network path. I've tried several ways of doing this, but I haven't found why this is failing.This is all I get:ESRI.ArcGIS.Client.Local.LocalServerException was unhandled Message=Failed to create service clark MapServer. Service failed to initialize: IObjectConstruct::Construct (MapServer) hr=0x80043000 (ErrorInfo did not include a description) Error code: 500 Source=ESRI.ArcGIS.Client StackTrace: at ESRI.ArcGIS.Client.Layer.OnInitializationFailed(EventArgs e) at ESRI.ArcGIS.Client.Layer.Initialize() at ESRI.ArcGIS.Client.FeatureLayer.Initialize() at ESRI.ArcGIS.Client.Local.ArcGISLocalFeatureLayer.FailInitialize(Exception error) at ESRI.ArcGIS.Client.Local.ArcGISLocalFeatureLayer.CompleteServiceInitialize(LocalMapService mapService) at ESRI.ArcGIS.Client.Local.LocalMapService.<>c__DisplayClass1.<GetServiceAsyncInternal>b__0(Object s, AsyncCompletedEventArgs e) at ESRI.ArcGIS.Client.Local.LocalService.OnStartCompleted() at ESRI.ArcGIS.Client.Local.LocalService.FailStart(Exception error) at ESRI.ArcGIS.Client.Local.LocalService.<ContinueStartService>b__a(CreateServiceResponse createServiceResponse, RequestInfo createServiceInfo) at ESRI.ArcGIS.Client.Local.Internal.Requests.ProcessResponse[TExpectedResponse](String url, String queryParameters, Exception err, Boolean cancelled, String result, Action`2 callback) at ESRI.ArcGIS.Client.Local.Internal.Requests.<>c__DisplayClass7`1.<Start>b__2(Object s, UploadStringCompletedEventArgs e) at System.Net.WebClient.OnUploadStringCompleted(UploadStringCompletedEventArgs e) at System.Net.WebClient.UploadStringOperationCompleted(Object arg) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs) at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler) at System.Windows.Threading.DispatcherOperation.InvokeImpl() at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state) at System.Threading.ExecutionContext.runTryCode(Object userData) at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean ignoreSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Windows.Threading.DispatcherOperation.Invoke() at System.Windows.Threading.Dispatcher.ProcessQueue() at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs) at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler) at System.Windows.Threading.Dispatcher.InvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs) at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam) at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg) at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame) at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame) at System.Windows.Application.RunDispatcher(Object ignore) at System.Windows.Application.RunInternal(Window window) at System.Windows.Application.Run(Window window) at System.Windows.Application.Run() at AdvancedRuntimeControls.App.Main() in C:\Users\gfaraj\Desktop\Source_Code\AdvancedRuntimeControls\obj\Debug\App.g.cs:line 0 at System.AppDomain._nExecuteAssembly(RuntimeAssembly assembly, String[] args) at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args) at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly() at System.Threading.ThreadHelper.ThreadStart_Context(Object state) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean ignoreSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.ThreadHelper.ThreadStart() InnerException:
The code: LocalMapService localMapService = new LocalMapService() { Path = @\\dtdev7240w7\Terminated\GIS Data\clark gis\clark.mxd, MaxRecords = 100000 }; localMapService.StartAsync(localService => { if (localService.Error != null) return; ArcGISLocalDynamicMapServiceLayer layer = new ArcGISLocalDynamicMapServiceLayer(localMapService); MyMap.Layers.Add(layer); });Other attempt:MyMap.Layers.Add(new ArcGISLocalFeatureLayer(@\\dtdev7240w7\Terminated\GIS Data\clark gis\clark.mxd, "Clark"));
