Hi, I'm trying to dynamically export my data driven pages to an PDF. Right now, the script successfully creates the data driven pages. We have to manually hit the "Refresh" button and then manually do File -> Export to PDF.I've tried this 2 ways (Option 1 & 2 below).For some reason, it's erroring out on any code the tries to use dataDrivenPages functionality.Has anyone witnessed this before or see what I'm doing wrong? I have to 2 options commented out for now.Thanks,Chris# Import arcpy moduleimport arcpyarcpy.env.overwriteOutput = Truemxd = arcpy.mapping.MapDocument("CURRENT")# Script argumentsMap_Scale = arcpy.GetParameterAsText(0)Page_Size = arcpy.GetParameterAsText(1)Output_Grids = arcpy.GetParameterAsText(2)Stand_Layer = arcpy.GetParameterAsText(3)# Process: Verify Page Sizeif Page_Size == "11 x 17": Page_Width = "9.5 Inches" Page_Height = "13.5 Inches"else: Page_Width = "7 Inches" Page_Height = "8 Inches"# Process: Grid Index Featuresarcpy.GridIndexFeatures_cartography(Output_Grids, Stand_Layer, "INTERSECTFEATURE", "USEPAGEUNIT", Map_Scale, Page_Width, Page_Height, "", "", "", "", "NO_LABELFROMORIGIN")arcpy.SetParameterAsText(4, Output_Grids)# Option 1#mxd.dataDrivenPages.refresh()#arcpy.mapping.ExportToPDF(mxd, r"D:\Clearion Data\testExport.pdf")# Option 2#tempPDF = r"D:\Data\testExport.pdf"#ddp = mxd.dataDrivenPages#ddp.exportToPDF(tempPDF, "ALL"}
Přihlášení členové mohou přispívat, sledovat novinky a dělat další věci. Jste tu noví? Zaregistrujte si bezplatný účet.
