Missing the Saturday column in the calendar picker in the Query widget. See below, replicated on different orgs with different datasets. Anyone else experience this, possibly have a fix?
I'm seeing all days when I set up the widget
SO strange! For me, when I set up the query to use the "in between" option, Saturday is not there. When I use the "after" query, like you have shown the calendar picker displays as it should. Weird quirk indeed. Thanks for helping troubleshoot!
I didn't see any problem in setting it up with the "in between" option.
Could the issue be theme specific? Kristin What theme are you using?
Thanks for the suggestion, I think you're right that the issue is theme specific.
The "problem" theme is the Launchpad theme.
I just created another app this morning using the Foldable theme and the calendar picker is working as expected.
