Hi,I couldn't import this widget because widget name conflict with existing Coordinate widget name. Help please.Thanks.
I'm just in the process of updating to 3.1 at the moment. I have had to go back to Kerry Coffin who works for ESRI in the states as the compiled libraries that I am using seem to place the grid in the wrong place. I will update as soon as I can.RegardsAnthony
Will,Error Code #2036 usually means that a path to one of your widgets is incorrect in your config file, i think flex is case sensitive so just check to make sure everything is alright. Also the two coordinate widgets are added in the UI area of your config file not the normal widget area.As for the labels being cut off by the banner set an attribute of bottom="25" in the map element.I will look into setting an option of have the grid enabled or disabled in the config file.
