Marc,Sorry for the delay in responding been a bit tied up in work, hopefully the attached zip will answer your questionsRegardsAnthonyPS. Please don't forget to mark post as answered[ATTACH=CONFIG]12348[/ATTACH]
Not sure what you mean by 'adapt the right click/copy widget to this format as well' this should be included in the zip file posted 03-01-2012, 01:28 AM. The config file allows you to set any coordinate system.
Marc,I have looked at it on my system and the right click copy MGRS is working as it should. Just in case we have had a mix up of files along the way somewhere I have attached a zip file containing the 3 widgets (coordinate, coordinatemenu & MGRS) that are all working on my system.RegardsAnthony
Will,Error Code #2036 usually means that a path to one of your widgets is incorrect in your config file, i think flex is case sensitive so just check to make sure everything is alright. Also the two coordinate widgets are added in the UI area of your config file not the normal widget area.As for the labels being cut off by the banner set an attribute of bottom="25" in the map element.I will look into setting an option of have the grid enabled or disabled in the config file.
