After some help with Eric, I have been able figure out how to group the group layers. The key was to create the Group Layer in the Table of Contents first and then drag in the group layer from the ArcCatalog Window. This worked at 10 Sp 3. Sorry for the previous confusion, I wrote ArcGIS, when I meant ArcScene. However, now I have learned the trick to do it.
No at ArcGIS you cannot nest the group layers together.
Grouping layers in ArcScene does work. I have no problem grouping the layers in ArcGIS 10 SP 3. .
