I have python script that creates a point feature class. How do I send that feature to an existing map using Python?
I believe you're looking for arcpy.mapping.AddLayer().
do you mean makefeaturelayer ?
My script already makes the feature and puts it into a file geodatabase. I would like it to also take that same feature class and drop it into an ArcMap.
so I assume you have ArcMap set to add results to display and set visibility on? And I have to ask the obvious...you are running this from within ArcMap? some people have tried to add layers to arcmap without it being open
I am using Python script that runs in the background.
# Import arcpy moduleimport arcpy
#Import Time and Dateimport timeimport datetime
#Sets a variable to hold today's date in year month day (yyyymmdd)format to tag feature output name with the current datecurrentdate = datetime.date.today().strftime("%Y""%m""%d")
# Overwrite pre-existing filesarcpy.env.overwriteOutput = True
# Local variables:Changes = "\\\\MyData\\Working_Data.mdb\\Changes"Changes_Layer = "Changes_Layer"Updates = "\\\\MyData\\My_Data.gdb\\Updates\\Updates"+str(currentdate)
# Process: Make XY Event Layerarcpy.MakeXYEventLayer_management(Changes, "longitude", "latitude", Changes_Layer, "", "")
# Process: Feature To Pointarcpy.FeatureToPoint_management(Changes_Layer, Updates, "CENTROID")
Now I would like to add Python script that will take "Updates"+str(currentdate)" and add it to MyDataUpdates.mxd
