Hi, I have trouble to login to the Flex Web edition. I used the default login name with no token used. I didn't use the token, because both AGS and database are on the local pc. The AGS has no security enabled.When I click Login, I got error message "HTTP Request error".I don't know if there is any error log, and I have no idea what caused the error.Please help. I attached the config.xml file.I've tested the map service of AOI, it works fine.BTW, I couldn't find the WMServer entry from the ArcGIS Server Service Directory. I am not sure if the entry is correct.Thanks for your help.Helen
Hi Helen,The ArcGIS Flex viewer is implemented differently from the ArcGIS Workflow Manager 10 if installed on ArcGIS Server .NET. What is the operating system you are deploying the web application on? If this is XP, there are some additional things that you need to do to get this working. Here is a link to an article to help guide you with this - http://resources.arcgis.com/content/kbase?fa=articleShow&d=38084To accomplish version switching on a web mapping application, you will have to do some customization using a combination of the Workflow Manager tools/step to create the map (with the job version) and then using the AGSSOM tool for publishing the map service on the fly. Here is a link to the article of publishing a map service programatically - http://resources.esri.com/arcgisserver/adf/dotnet/index.cfm?fa=codeGalleryDetails&scriptID=16293Thanks,Tope
