Ioannis, have you solved your probleb. Same case with me.After uploading QueryTool.AddIns.xap in Silverlight Viewer, the "Query Layer tool" does not appear in the Query category of Add Tool Dialog.Any suggestion how to overcome this problem?Higly appreciated.Ali Naqi
A new Query Tool is now available for the ArcGIS Viewer for Silverlight. The tool allows users of the Application Builder to interactively build queries against ArcGIS Server services, presenting end-users with a simple dialog box that prompts for values to plug into the query. End-users of a configured query tool are prompted to input query values into text boxes, drop-down lists, or both. Results are shown on the map and in the Viewer�??s attribute table. For developer's the tool's full source code is available.To get started using the tool or exploring its implementation, simply download it from ArcGIS Online.
I cant download the addIn, is the download link right?Thanks, Manuel
Thanks Jamal, seems that the problem is that is not allowed from my work. I will try to download it from home.Regards, Manuel
