That is a strange issue..Can you increase the sampling size to anything higher than the "Count"?Your count is 343809 so try to use a sampling size of 345000, for example.I think by default your sampling is set to ~10,000.
Look back at your first post, in the first screenshot.The sampling button is in the window where you modify the 'class ranges'.I think you press the "Classify" button inside the "Reclassify" tool.
Jamal,Please follow the steps in the knowledge base article to resolve this issue.HowTo: Compute the histogram with all the unique values, when using the classified rendererRegards,Eric
