import os, arcpy start = r"G:\DEPARTMENTS\GIS\Chris_Graff\temp\scketchup" sdeFile = r"G:\DEPARTMENTS\GIS\Chris_Graff\temp\Aerial.sde" for root, dirs, files in os.walk(start): for file in files: if file.endswith(".mxd"): path = os.path.abspath(os.path.join(root,file)) mxd = arcpy.mapping.MapDocument(path) print path for lyr in arcpy.mapping.ListLayers(mxd): if lyr.supports("SERVICEPROPERTIES") and lyr.serviceProperties["ServiceType"] == "SDE": if lyr.datasetName.upper() == "STATIC.DATALOADER.AP2008": print "! " + lyr.datasetName lyr.replaceDataSource(sdeFile, "SDE_WORKSPACE", r"AERIAL.DATALOADER.AP2008", True) print "NEW " + lyr.datasetName else: if lyr.isRasterLayer: print "!!!!" + lyr.datasetName else: print " " + lyr.datasetName else: print " " + lyr.name try: mxd.save() except IOError as e: print "Save failed!" del mxd, lyr, file, path
import arcpy, os from arcpy import env from arcpy import mapping env.workspace = workspace = arcpy.GetParameterAsText(0) env.overwriteOutput = True for (path, dirs, files) in os.walk(workspace): for file in files: if ".mxd" in file.lower(): mxd = os.path.join(path, file) print mxd + " is being processed" mxd = mapping.MapDocument(mxd) for df in mapping.ListDataFrames(mxd, "*"): for lyr in mapping.ListLayers(mxd, "*", df): lyr.replaceDataSource(arcpy.GetParameterAsText(1), "SDE_WORKSPACE", "") print "Successfully updated data sources" if "vector" in lyr.name: lyr.name = "RASTER.DATALOADER." + lyr.name.split(".")[2] print "Succesfully changed layer name" mxd.save() del mxd
if "vector" in lyr.name: lyr.name = "raster.dataloader." + lyr.name.split(".")[2]
lyr.replaceDataSource(sdeFile, "SDE_WORKSPACE", "AERIAL.DATALOADER.AP2008", True)
lyr.replaceDataSource(sdeFile, "SDE_WORKSPACE", "AP2008", True)
lyr.replaceDataSource(sdeFile, "SDE_WORKSPACE", "", True)
lyr.replaceDataSource(sdeFile, "SDE_WORKSPACE", "newName", True)
elif layr.datasetName == "ORTHO2005.ORTHOS2005": print("The dataset name in Resource_mxd is " + layr.datasetName) layr.replaceDataSource(r"\\gis\GIS\Work\arcmap\mosaic_2010.gdb", "FILEGDB_WORKSPACE", "orthos_2010")
