If TypeOf IFeature Is IComplexEdgeFeature Then End If
Dim layer As IFeatureLayer = New FeatureLayer Dim s As String = layer.GetType.FullName
IWorkspace pWorkspace = EsriDatabase.FileGdbWorkspaceFromPath("WhatEver.gdb"); Console.WriteLine(pWorkspace.GetType().FullName);
IntPtr iunkwn = Marshal.GetIUnknownForObject(pWorkspace); // enum all the types defined in the interop assembly System.Reflection.Assembly objAssembly = System.Reflection.Assembly.GetAssembly(typeof(IWorkspace)); Type[] objTypes = objAssembly.GetTypes(); // find the first implemented interop type foreach (Type currType in objTypes) { // get the iid of the current type Guid iid = currType.GUID; if (!currType.IsInterface || iid == Guid.Empty) { // com interop type must be an interface with valid iid continue; } // query supportability of current interface on object IntPtr ipointer = IntPtr.Zero; Marshal.QueryInterface(iunkwn, ref iid, out ipointer); if (ipointer != IntPtr.Zero) { string str =currType.FullName; } }
