Hey everyone,
I know this is an old thread but I'm in a similar situation, only using GeoServer 2.13 and ArcGIS 10.5. I'm trying to use a WMTS layer in ArcMap, and I can connect to it, and bring in a layer into the map, and it goes to the correct extent, but nothing actually renders. After reading Jim's comments, I checked our GetCapabilities document, and it has KVP encoding only. Anyone know how to add or enable RESTful encoding? Help would be much appreciated!
Hi,I have also been playing around with getting a WMTS service in ArcGIS 10.1 (SP1). I am using my own custom tiles through my own WMTS service (not Geoserver) which I can successfully pull in but when I overlay some building outline shapefiles I can see an offset of about 48 meters.I then also tried loading in the same City of Vienna's WMTS, mentioned earlier, and can see a similar offset when compared to loading in some OSM and ESRI Streets Basemaps (File>Add Data>Add Basemap...). Is there a known issue with displaying WMTS in 10.1?I ask because I noted some WMTS fixes in 10.2 release notes - but I don't yet have access to this version to verify...Jason
