In ArcGIS Online there is now an AI Assistant that can auto-populate metadata for a feature or image layer by executing a deep dive into the underlying structure of the feature class. This results in 'suggested' metadata that then can be Saved to the Document. When this tool is used a Disclaimer should be automatically added to the appropriate place in the metadata. For example:
Terms of Use (Use Limitation): "Metadata shown here was partially generated using an AI-Assistant. The outputs generated by AI may not always be accurate. We encourage you to review, fact-check, and adjust outputs as needed before relying on them. You are responsible for your use of the content generated using this AI feature."
