I would be very grateful if we could add more fields in the method "creating a tour from Feature Class":
Also, It would be cool to be able to add more photos with the method of using URLs:
This can be achieved today with a little data manipulation.
You can create a new field in your feature layer that combines information from several fields into a single field. Then, that new field can be set as the description field in the map tour so all the information you want is shown.
This workflow is very powerful and allows you to format the description field with multiple paragraphs, lists, links, and more.
You can create this new field using the field calculator on the ArcGIS feature layer item page or manipulate the data in your favorite spreadsheet app, like Excel or Google Sheets, and upload the CSV as a new feature layer.
Check out these blogs that describe the process:
Hi @OwenGeo, I would like to ask you about the second option regarding images, which is mentioned in this post above, i.e. "it would be cool to be able to add more photos with the method of using URLs".We have several images for each feature and these images are entered in the attribute table using their URL link in individual fields, i.e. one field = one URL link. I tried to enter multiple URL links in the new field and this field is set as Image URL field. But no images were displayed in the header of Description field in my Map Tour.So I tried at least to add multiple images directly to attribute for Description field via <img src=(HTML tag), but this does not work for me. These images are only displayed in pop-up, not in Description field in my Story map.Thank you for your answer.
@IrenaKřečková - Adding images to the tour place description isn't available at this time. We will continue to monitor this idea for votes to see if adding multiple images via URL fields in a feature layer is something more people want as we evaluate future enhancements to map tour.
For now, you can add multiple images to each point of a feature layer as attachments to show multiple images for a map tour location.
Přihlaste se pro psaní příspěvků, sledování obsahu a další. Jste tu noví? Zaregistrujte se zdarma.
