I have 8 tracts with different owner names. How can I have the "Tract of Interet" named tract display that tracts OWNER for each map series page? I"m unable to find any useful help via the interweb 🙂 Thank you!
Oh, just symbolize by unique value and then make all the symbols the same.
Then have your legend item only show features visible in the map extent.
You might need to pair with a Page Query depending on your needs
Is that owner information present in the same feature class that's driving the Map Series?
If so, this is relatively straightforward. You'll want the attribute property in the dynamic text options, which you can find here.
If that owner information is stored somewhere else, like a Related Table, this gets slightly more complicated, depending on the relationship and/or data structures in question.
I know how to do the attribute table via map series dynamic text. But, still do not know how to turn the "tracts of interest" to show JOHNNY ROTTEN in its place.Â
Ah, displaying it in the legend is quite a bit different; missed that part of the puzzle. Alfred's solution is indeed how I would (and have) accomplish that.
I did Alfreds, but I cheated. I did a map series and made a copy of the series to get the individual maps 🙂
Glad to hear you got it working!
Remember to hit "Accept as Solution" when someone's suggestion works for you, because it helps ESRI and us MVPs track things on the boards.
PĹ™ihlášenĂ ÄŤlenovĂ© mohou pĹ™ispĂvat, sledovat aktualizace a dalšĂ. Jste tu novĂ? Zaregistrujte si bezplatnĂ˝ účet.
