Hi! It's not the biggest issue, but it's happened enough times since using Pro that I thought I'd ask here.
When I go to rename a gdb file in the catalog pane, it's a hit or miss when the new name holds or throws the 'Rename Failed' error. I try with the .gdb and without, and it eventually either works (rarely on the first try), or I give up, get out of the program, rename the file in my file explorer then reopen the project.
Is this normal? Is it me? Does anyone else experience this issue?
Thanks!
*I should mention that this seems to happen whether or not data from the gdb is being used in a map.
