Nahrávám online mapu na webové stránky mé skupiny na SharePointu. Když otevřu mapu v AGOL, otevře se ve správné orientaci, kterou potřebuji; avšak po nahrání na SharePoint se orientuje na sever. Existuje nějaký způsob, jak tomu zabránit?
Hello @ItzelPretzel --
Thanks for posting your question on Esri Community. Would you be able to share some additional details? Are you noticing this issue with all webmaps or is it only noticed with certain webmaps? Would you be able to share the webmap (if possible)? Or would you be able to share a screen recording?
Thanks in advance.
Thanks & Regards,
Raaj
Yes, it seems to be all of our maps that are shared onto SharePoint only. When the online map is opened on AGOL, it opens in the correct orientation. Unfortunately, I cannot share the webmap or screen record. If you know of an alternative way to show an interactive map in a custom orientation and can be posted on sharepoint, that would be great!
Got it. You'd like to see the orientation and the extent persisted when you add the "web map" to the "ArcGIS" web part in the ArcGIS for SharePoint app, am I correct?
Yes this is exactly what I would like to see 😊
Thanks for confirming. We will do our best to rollout this functionality in the next release. Stay tuned!
