How to download part of a .tpk file in latest version of xamarin SDK 100.0.0.
In earlier version I have used this .NET Xamarin gist to download ArcGIS basemap tiles for offline use. · GitHub
it has worked fine but after updating the SDK getting build errors
Something like this
<SPAN class="keyword token">var</SPAN> overlay <SPAN class="operator token">=</SPAN> MyMapView<SPAN class="punctuation token">.</SPAN>GraphicsOverlays<SPAN class="punctuation token">[</SPAN><SPAN class="string token">"areaOfInterestOverlay"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>overlay<SPAN class="punctuation token">.</SPAN>Graphics<SPAN class="punctuation token">.</SPAN>Count <SPAN class="operator token">==</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">return</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> basemap <SPAN class="operator token">=</SPAN> MyMapView<SPAN class="punctuation token">.</SPAN>Map<SPAN class="punctuation token">.</SPAN>Basemap<SPAN class="punctuation token">.</SPAN>BaseLayers<SPAN class="punctuation token">.</SPAN>OfType<SPAN class="operator token"><</SPAN>ArcGISTiledLayer<SPAN class="operator token">></SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">First</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> lods <SPAN class="operator token">=</SPAN> basemap<SPAN class="punctuation token">.</SPAN>ServiceInfo<SPAN class="punctuation token">.</SPAN>TileInfo<SPAN class="punctuation token">.</SPAN>LevelsOfDetail<SPAN class="punctuation token">;</SPAN> ExportTileCacheTask estimateTilesTask <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN> ExportTileCacheJob job <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">try</SPAN> <SPAN class="punctuation token">{</SPAN> estimateTilesTask <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">await</SPAN> ExportTileCacheTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">CreateAsync</SPAN><SPAN class="punctuation token">(</SPAN>basemap<SPAN class="punctuation token">.</SPAN>Source<SPAN class="punctuation token">,</SPAN> Authenticat ionManager<SPAN class="punctuation token">.</SPAN>Current<SPAN class="punctuation token">.</SPAN>Credentials<SPAN class="punctuation token">.</SPAN><SPAN class="token function">FirstOrDefault</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> parameters <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">await</SPAN> estimateTilesTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">CreateDefaultExportTileCacheParametersAsync</SPAN><SPAN class="punctuation token">(</SPAN> overlay<SPAN class="punctuation token">.</SPAN>Graphics<SPAN class="punctuation token">.</SPAN><SPAN class="token function">First</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>Geometry<SPAN class="punctuation token">.</SPAN>Extent<SPAN class="punctuation token">,</SPAN> lods<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>Scale<SPAN class="punctuation token">,</SPAN> lods<SPAN class="punctuation token">[</SPAN><SPAN class="number token">10</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>Scale<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> job <SPAN class="operator token">=</SPAN> estimateTilesTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">ExportTileCache</SPAN><SPAN class="punctuation token">(</SPAN>parameters<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">@"yourpathtothetpk.tpk"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> result <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">await</SPAN> job<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetResultAsync</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//await result.LoadAsync();</SPAN> <SPAN class="comment token">// Do something with loaded tile cache</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">catch</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="token class-name">Exception</SPAN> ex<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> Debug<SPAN class="punctuation token">.</SPAN><SPAN class="token function">WriteLine</SPAN><SPAN class="punctuation token">(</SPAN>ex<SPAN class="punctuation token">.</SPAN><SPAN class="token function">ToString</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">foreach</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">var</SPAN> joMessage <SPAN class="keyword token">in</SPAN> job<SPAN class="punctuation token">.</SPAN>Messages<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> Debug<SPAN class="punctuation token">.</SPAN><SPAN class="token function">WriteLine</SPAN><SPAN class="punctuation token">(</SPAN>joMessage<SPAN class="punctuation token">.</SPAN>Message<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
