I am building a site on Hub (basic) and having an issue with the header. When I am editing the site the header appears as normal, but when I switch to 'View published' the header completely disappears. I tested this in a blank site with just a header and the issue still occurred (screenshots attached). Apologies if I am missing something obvious but I have tried everything I can think of.
This issue was resolved on production this morning. Thank you for reporting it to Esri Support Services!
Hi @LaytonT I have the same issue !!
Hi @Muhammad_Elbagoury
I ended up contacting technical support and it looks like it's bug. I'd try contacting them as well if I were you.
Hi @LaytonT;Thanks a lot for the update! Appreciate you letting me know.
