Hi all,
Using Enterprise 11.3, I've published a feature service that references data in a SQL Server 2017 DB but it doesn't support pagination. It's my understanding that anything past SQL Server 2012 should support this functionality by default. Is there anything specific I should be looking at to enable this? Images attached.
Update: The service contained a tabular join to a view in another DB. After removing the join pagination became enabled. Is there any way to maintain such a join while keeping the pagination capability? Moving the view into the same DB as the feature class also breaks pagination.
@BenClark I realize this is more than a year later, but did you ever find a way to maintain the join and have the pagination capability enabled?
Hi, @Scott-Shavnore . Nope, never did sort this out. If I remember correctly I also needed to upgrade the enterprise geodatabase from 10.9.1 via ArcGIS Pro, but it somehow became corrupted in a way that prevented that, so I just made due without pagination.
