When building an expression in ArcGIS earth with multiple lines, the first "contains" gets filled in with a value from the dropdown.
Thank you for reporting this issue. We were unable to reproduce this behavior on our side. Could you please provide more details, such as the exact steps to reproduce it or screenshots? This will help us investigate further.
Hi! Yes - I just encountered the issue again. It occurs when I want to use "contains" and fills in a value from the dropdown. When I change it back from "ABC DEF" to just "ABC" for example, it will change it back to "ABC DEF" since it matches a dropdown value.
