Archanawhen we are publishing the web application in SOM, first we have to choose map service and after that we have to select supporting services and then add: address locator ( geo code service) and then add task as find address. and then configure. map service published sucessfully. then it will visible everything on wep maping application: like find address, results are showing.RegardsJagadeesh
ArchanaPlease open a support call with Esri, the analyst will track this issue to resolution.Regards
My guess is that the feature dataset is your problem. Is there a compelling reason why your featureclass(es) need to be n a feature dataset? You might try to put the feature class in a geodatabase with out it being a member of a feature dataset and see if it works. Another trick I've recently learned (after geocoding gazillions of addresses) is to put the actual locator in a folder rather than have it stored in a geodatabase.Hope this helps-
