Hi, I had a task to make a Python script that would be used as a script tool in ArcGIS Pro, this script should loop through the items in an enterprise geodatabase and check each item if it is a view or not, if the item is view it will be forwarded to a database called "views_db" and if not, it will be forwarded to a database called "items_db".
First, I tried to use Describe function that describes the properties of each item, but I couldn't find any property can recognize if the item in gdb is view or not.
I used another approach based on that, views are not editable at all not like feature classes, tables and so on. This approach is to try to add a new row in the feature class or table, if the feature class or table accepted inserting a new row, the item will not be treated as a view, and vice versa. For my case it worked successfully till now, but in a long-term use, if there's any item that is not editable and not a view, it would be considered as a view.
So, if you know another idea to differentiate between views and other items, please share it here.
