In our Electric Utility network we have parallel lines running from the same feeder OR 2 Circuits running from the same feeder. Meaning in the Substation we have one feeder or one circuit breaker with two lines coming out of it. Then this runs out into the distribution system and both lines are feed into on individual switch for a customer. It also runs tees into another direction where it hits an open switch on both lines that is connected to another feeder that is also two parallel lines out of the same feeder/circuit. What is happening is because I have one device connecting two lines at one end and another device connecting the same two lines at the other end, I'm getting a loop. How would I go about depicting this, keeping in mind that I have to export the JSON to our OMS system that is also reading the loop. Below is a small diagram to hopefully better explain.
