Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
Custom widgets can be added on premise Portals but you can not add them through a web map.
Add custom widgets—Portal for ArcGIS | ArcGIS Enterprise
Hello Robert,
My Team published a Web Map as a PUBLIC with App ID on premise as well as
ArcGIS Online that contains layers on the web map.
I want to know whether they can share the custom-made widgets on the web
map containing App Id.
I am able to get our web map containing layers using App Id from the ArcGIS
online and On-premise Portal. I want to know whether I can get the
custom-made widgets also using App Id if our Team is able to publish
custom-made widgets and layers when they publish the web map as a PUBLIC.
Please answer my question.
Thanks
Suresh
On Sat, Dec 8, 2018 at 9:22 PM Robert Scheitlin, GISP <geonet@esri.com>
Suresh,
Your additional detail does not change the answer. As straight forward as I can answer... Yes a custom widget can be added to an on premise Portal, using the instructions provided in the link I posted earlier.
Whether the webmap is public or not is irrelevant to the registering of a custom widget. If the WAB app is hosted on AGOL then the answer is NO a custom widget can not be published to that AGOL WAB app.
I want to know whether they can share the custom-made widgets on the webmap containing App Id.
No registering a custom widget has Nothing to do with specific web map. A custom widget is registered with the whole on premise Portal installation.
Thanks Robert.
On Sat, Dec 8, 2018 at 11:30 PM Robert Scheitlin, GISP <geonet@esri.com>
Robert,
Is it possible to access registered custom widget from on-premise portal
Yes
Thanks ROBERT. I will try as you suggested.
On Sat, Dec 8, 2018 at 11:58 PM Robert Scheitlin, GISP <geonet@esri.com>
