We have a license server with 10.2 LM. We need to move 10.0 license from a different server to the server. Is it possible?
If so what will be the process.
Thanks in advance..
Yes.
Deauthorize the license from 10.0 LM.
While authorizing in 10.2 LM, choose ver. 10.0 from the dropdown.
NOTE: Keep the license code with you for the authorization.
ArcGIS Desktop 10.0 machines should be able to access a 10.2 LM with no problem.
If if you are trying to move or combined licenses from two different LM into on 10.2, that is possible if they are all licensed for 10.2 or above, or if they are on current maintenance. In that case you can follow Jayanta Poddar advice. If they are not licensed for 10.2, that will not work.
Keep in mind that if you have a total of, let's say three 10.2 licenses that are on maintenance and previous were 10.0, your myEsri page may look like you have three at 10.0 and three at 10.2, but it is really an "or". That is, you only have the quantity that you have had on maintenance, not double. That is always a bit confusing on that page.
edit. For license manager 10.2 .. Quick Start Guides
Hi Jayanta Poddar, @rebecca,
Thanks for responding..
So does it mean that if I have to keep both 10.0 & 10.2 licenses in a 10.2 LM that won't be possible?
You can. After deauthorizing the older version of the concurrent license from 10.0 LM, authorize the license in 10.2 LM. In LM 10.2, choose 10.0 from the drop-down, and click "Authorize Now" and follow the instructions.
