Hi all,
When trying to publish a hosted Tile Layer, I get an error message regardless of how I try to publish the tile package. For example:
From ArcGIS Pro 3.3.2: Tile Generation goes well (tried both offline and online tile generation). Tile package is uploaded successfully but fails upon publishing. The log files say the follow:
StatusMessage: Publishing web layer failed (AGO)
StatusMessage: Publishing tool execution failed
ErrorMessage: Failed to publish web layer
Also manually trying to publish the uploaded tile package fails with the following message:
"The item you requested cannot be found. The item may have been deleted or you may have entered an incorrect URL"
From ArcGIS Online: by uploading the .vtpk file. Either option, uploading and publishing directly or publishing manually after in ArcGIS Online don't work either.
If I publish the exactly the same tile package in a different organization, it works. Which makes me think that the problem is either in the settings or the rights or storage structure of the ArcGIS Online organization. The organization consists only out of 1 person who has administrator rights. I logged a call with the local ESRI support team but no success yet, looking forward to learn if anyone here has suggestions or similar experiences. Thanks in advance!
