It appears that snapping in an ArcPro Layout is still not working. Can someone say when this will be fixed?
I've read the docs and I think I'm doing it correctly, but I keep getting the same response. I'm using version 2.0.1.8933
Thanks.
In your Layout View to the right of the scale box is a Snapping button to click. If it turns blue, you've enabled snapping. From there, you can choose to snap to guides and/or elements. I'm using ArcGIS Pro BETA 2.1 for testing.
Hi Greg,
I've had the same issue regardless of whether snapping is turned on. I think this has to do with the margin to the paper edge. Try creating guides at 1/4 inch (or larger), and see if the snapping works okay.
Seth
Nevermind, I can't get it to behave consistently.
ArcGIS Pro often forgets that snapping is turned on. Usually, you can fix this just by restarting the application.
Thanks for the reply Rob. The snapping button appears to have no effect (whether on or off)...
Greg
If you hover your mouse over the Layout Snapping, it "expands" a small UI. Inside you'll see Guide Snapping and Element Snapping. Click either or both to enable those two snap agents in the Layout. I'm working with Pro 2.0.1 so do not know if 2.1 Pro will have additional snap agents.
Hi Rob - thanks again. See attached animated gif. Am I missing a step?
Also, I'm currently using ArcPro version 2.0.1
I see what's happening - when you hover over the Layout Snapping area, you're just turning it on/off but setting the snap agent. Below Snapping is off/Snapping is on, click one or both snap agents so they too are blue.
I hadn't tried that one yet... I'll have to remember that!
Hi - the update to ArcPro v2.1.0 fixed this problem. Thanks
I have found that in 2.1.1 that the snapping (in layout view) is automatically enabled every time you reopen a project even though the snapping button shows its off. You need to cycle it on then off again for snapping to be disabled. This is a new bug introduced in 2.1.1
I, too, am having this problem. I have done all that you suggested, as well as the suggestions to restart the program. The snap feature will still not work for me, even though the snap icon at the bottom left says that it is "on". I'm using 2.3.1.
Jeanette,
Have you tried messing with the snapping settings in the snapping area?
Have you gotten other layers to snap? What kind of layer are you trying to get to snap (point, line, polygon, etc.)?
