Hi! I am having a weird issue with two Field Maps, one of which I created by duplicating the other. The only major difference between them is the geographic region: one is for an island, and one is for the mainland.
To ensure the island Field Map didn’t show mainland points, I applied a filter based on a field (Area) that specifies the location. To simplify the workflow for users, I created a template in each Field Map so that new points would automatically be assigned either "island" or "mainland" in the Area field. This worked perfectly fine.
However, today I noticed that one of the Field Maps was showing template options from the other. When I modified the template in one map, the changes also appeared in the other. It turns out that the templates are somehow linked—any change I make in one Field Map is automatically reflected in the other (see video below). I tested this by duplicating other maps, and their templates are also linked.
My questions:
- Why are the templates linked between duplicated Field Maps?
- Was there an update that introduced this behavior?
- How can I separate the templates so they remain independent?
Thanks!
Side note: The only reason I duplicated the Field Map was to avoid manually recreating a complex form with linked tables, as it contains many fields and pop-ups that would take a long time to reconfigure. Because of this, I was forced to work with the same hosted feature layer for both maps. Ideally, I would prefer to have a separate layer for each region without losing the form configuration. If anyone has a solution for that, I’d love to hear it!
