Is it possible to upload a csv file to portal or create a feature service using the pro sdk? I couldn't find any samples in the documentation.
@CharlesMacleod @UmaHarano @Wolf
Hi @MK13
Here is a code snippet - I will add this to our docs too for posterity.
// Create EsriHttpClient object var httpClient = new EsriHttpClient(); // Upload CSV file to ArcGIS Online var itemToUpload = ItemFactory.Instance.Create(@"C:\Data\AddToMapCustomItem\AlaskaCitiesXY.csv"); string[] tags = new string[] { "ArcGIS Pro", "SDK", "Internal Demo" }; UploadDefinition uploadDefinition = new UploadDefinition( ArcGISPortalManager.Current.GetActivePortal().PortalUri.ToString(), itemToUpload, tags ); var result = httpClient.Upload(uploadDefinition); if (result.Item1 == false) return; Thread.Sleep(2000);
@MK
Can you please explain a little more? You have custom data in a csv?
@UmaHarano yes. I have custom data that I generate in a pro sdk addin that I would like to save to ArcGIS Portal either as a csv file or a feature service.
@MK13
As you might already know, a plugin data cannot be shared as a web layer.
But, a csv file can be shared to an ArcGIS Enterprise portal- Here is a document that lists all the supported items on an ArcGIS Enterprise portal:Content you can add in the ArcGIS Enterprise portal
@UmaHarano do you have some example code to share a csv file to portal using the pro sdk?
You will have to use EsriHttpClient to upload the csv file. I don't have a code snippet for it yet - will try and share some code in the next couple days.
Hi @UmaHarano , have you had a chance to find a code snippet for an upload to portal? The documentation has lots of examples for get requests but no post examples.
Works perfectly. Thanks!
