Is there a maximum recording and picture that can be taken during a data collection with Collector for Arcgis offline?
I had some error synch in the past and I want to know if the number recording may be related to my issue.
Thanks
The connection speed might not be strong enough for the size of the upload and may timeout.
There is no restriction to attachment sizes in offline mode. When on iOS the max video time is 10 mins (online and offline) and there is no limit to the number of photos being taken and attached to features. If you are adding a large number of attachments to be uploaded you will want to be near a strong wifi signal. Also remember when you hit sync you are also pulling down map changes within the offline extent and those could include other field crew members and contain a large # of attachments as well.
thanks
There is some problem in 3G ?
When we were using the iPhone 4S with collector and it did not have LTE we used an app on the phone to shrink the attachment size and it seemed to work well.
