I suspect what is happening is that the display pipeline is not able to keep pace with the constantly changing map rotation, especially because the iPad 3 retina display requires a lot of fine detail in the graphics.As a workaround, can you try disabling the renderNativeResolution property on all the graphics layers and see if that makes things better? I have a feeling it might because the graphics layer will not try to draw in such great detail. You may see a slight degradation in the crispness of your graphics, but it may not be noticeable.Please let us know.And thank you for reporting this, your feedback is very helpful.
Přihlášení členové mohou přispívat, sledovat novinky a dělat další věci. Jste tu noví? Zaregistrujte si bezplatný účet.
