Understoood; however the funny thing is that only one person is editing. Every other user is simply viewing the file.
Hi, Is there any way to edit data in file geodatabase with ArcGIS Basic and share it for viewing with ArcGIS Server map service without stop\start service by user?It seems I could edit data in personal geodatabase in ArcMap and see changed data in ArcIMS ArcMap service earlier. ThanksOleg
"You can edit the data VALUES"Is it true for ArcGIS Desktop Basic (former ArcView) and file geodatabase? As I understood from previous post it is possible trouble due file geodatabase locks?ThanksOleg
I am haing a similar issue, we have a file geodatabase that we access through ArcGIS 10.6 and QGIS 2.18.x and 3.4.6 and 3.6.1. QGIS was being used to make some simple edits and changes without issue. Suddenly several layers started throwing the error "Failed to Update Row (User does not have permission to execute this operation); No ones user permissions have changed to caused this. My ArcGIS is still able to edit and there are no locks on the data anywhere in the filegeodatabase so we don't understand what the issue is. As it is I am the only one able to edit and this is a huge hindrance because there are more edits than what I can do. I tried compressing/uncompressing, compacting, copying. The only thing that sort of worked was exporting the effected layers to a shapefile, deleting them from the geodatabase, and importing the shapfiles back into the database. Any thoughts on this one?
