We recently released two blogs discussing the new GeoAI toolbox in ArcGIS Pro 3.0.
This discussion is for questions related to the blogs or the tools themselves, or to share how you are using these tools or any feedback you have on them.
Quick question:
I am training using autoML and have successfully done this before with the tool, but now the training tool will not work. Every time I try to train the tool shows me it is processing features, and then gets stuck at the same point every time and eventually fails. I have identified that it is getting stuck processing the one training distance feature. I have tried repairing the geometry, redownloading the data, etc. but nothing helps it always gets stuck at the same point of processing. This is also weird because I have used this exact same data for training a distance feature previously and have changed nothing. it just doesn't work now. Any help would be amazing, thank you.
Hi @KManl, thanks for the question. So you've used the Train Using AutoML tool successfully, and it just started not working? If you remove the one problematic training distance feature, does the tool run successfully?
Hi @NicholasGiner1,
I have fixed the issue now. But I have run into a new one. I am running the autoML tool to predict species richness (predict to raster) based on all 19 bioclimatic variables (rasters). When predicting for much different future scenarios the prediction result is always the same even though the model inputs are different for each scenario (i.e. under different future climate scenarios). What am I doing wrong here?
Thank you for your help.
Hello, I want to ask why I put grid data in the training grid to explain that the dataset does not exist or is not supported.
@jiewilliam Could you provide data and steps to reproduce the issue?
@KManl Could you provide data and steps to reproduce the issue?
First of all, thank you very much for your reply. I have solved the above problems. But I have a new question to ask you. When I use AutoML to predict, why will memory continue to grow, leading to the final software flash back? At the same time, I also use pychar's arcpy to try this data, but still encounter the problem of memory continue to grow, leading to software flash back. My running memory is 16G, with 3060 gpu and i5-12450 cpu.I don't know if it's my software settings. When running programs, the utilization rate of CPU and gpu is very low, but the memory has been growing.
What are the total number of records In prediction set ? Do you see this behavior while predicting even when the number of records is small ? Or does it happen when number of records exceed a specific number ?
That happens when the number of samples is 31488499. When I reduce the number of samples to 85555, it can run normally.
@jiewilliam Wow!! that's big number!!
I think 31M records is too much to be processed on a 16GB machine. I do not think RAM is sufficient in that case. I would suggest to get the prediction results in smaller chunks.
Hi Nicholas,
Thanks for the Blog. I am reasonably new to ML and have previously had some limited experience with RF. I have begun trialling the AutoML tool in Arc and have a number of questions I was hoping I might be able to get you to help me with.
Thanks again for your blog and any help you may be able to offer in helping me grasp the fundamentals of the tool.
GRAB 1
GRAB 2
Hi Christopher,
I will try to answer some of your questions:
1. If you leave the algorithm feild blank, then the tool will try to fit all available models on your data. However, if some of the model training fails during the process then that model is ignored and the tool proceeds to fit the next model on your data. In your case it looks like the a decision tree and a LightGBM models were trained and the other models couldnt be fitted.
Second part of the first question - Yes. These are different variations of decision tree with different hyperparameters and different variable combinations.
2. Yes. Ensemble is a combination of multiple models. The composition, performance and other details of the ensemble model can be found in the report that the tool generates. You can also use this report to compare other aspects of the evaluated models. Please note that the report is an additional optional parameter which you can choose to generate (Please lookout for the report parameter under additional outputs section of the training tool).
3. Yes. The best performing model is what is saved in the *dlpk. At the moment, there is no option to choose any other model apart from the best model for inference.
4. The variables that were used during the training are saved in the dlpk and when you provide a feature class/shape file to the inference tool, the tool tries to find the variables with the same names in the provided shape file. In case the names of your fields in inference shape file are different from what you had used during the training, then you will need to provide a mapping of the fields in the Map Explanatory variables section of the Inference tool.
Hope this helps.
~ Karthik
Edit - You can also try to run the tool in Advanced mode. The tool might pickup more models when you choose this mode.
Hi Karthik,
Thanks very much for your detailed response.
I haven't been able to find any details of the compisition of the ensemble. Will this always be what is used? I would imagine an ensemble is always going to give a bettter result than an individual model?
Hi Nicholas, I am running the Train using AutoML tool in ArcGIS Pro, it works in my PC (version 3.0) but in my laptop with ArcGIS Pro 3.1, it's not working, although I used the same dataset. I have attached the problem here. Can you please let me know how to fix this? Many thanks
Many thanks,Duy
An ensemble will always be created but it does not necessarily mean that it will be the best model. There will be a few cases where the individual models work better compared to ensemble. But in majority of the cases ensemble will be better than individual.
In order to get the composition, you will need to generate the report. In the report, if you click on the ensemble model, the composition will be displayed. You can generate the report by populating the parameter Report (In additional outputs) before you run the tool. The tool output window will then show you a link to the report that was generated.
Karthik
Hello Duy,
Would you be able to share the dataset? We will have to try recreate this issue.
Hi @NicholasGiner1
Very interested in this rideshare demands prediction demo(EsriDevEvents/ds-usa-plenary-automl-2023: This demo highlights new AutoML capabilities within the GeoAI toolbox during the Day 2 DevSummit 2023 Plenary. (github.com)), but unable to downlaod the ArcGIS Pro project package file listed on the webpage, need to login with an Esri credential, can you please make it public?
@NicholasGiner1
I would like to report one possible bug, when I am using the AutoML tool in a disconnected environment or when current portal is set to a portal with self-signed certificate, the tool will return error messages.
Upon checking the source code, I noticed it trying to connect to the portal, can you explain why this is necessary? Becuase I didn't see any parameters in the tool that related to the portal.
@xingchenc Thanks for reporting the issue. We have logged this as a bug internally. Please expect the fix with Pro 3.3 release.
@PriyankaTuteja
Hi Priyanka,
Thank you ,that's good to know!
Hi @xingchenc - thanks for reaching out about this. I've reshared the link publicly, please let me know if you have any issues accessing it.
DevSummit2023_AutoML_PlenaryDemo_April2023.ppkx
thanks,
Nick Giner
@PriyankaTuteja @NicholasGiner1
I am using the Train AutoML and Predict AutoML tools in 3.1. I can successfully train my model using raster data as input, however when using the predict to raster tool it keeps asking for a point file (i.e. the red asterisk never disappears) and so the tool won't run. "Parameter missing error".
If I train the tool on a point dataset (i.e. extract values from the rasters first), and then also run predict on a point dataset (again with values extracted from the rasters) everything works fine.
Do you have any suggestions why predict to raster won't run?
Thanks for your help.
Cheers,
Ollie
My goal is to predict 28 different ecozone types (acidic cove, northern hardwood, etc) using plot data (n=5,000ish) and about 44 different environmental variables as explanatory variables. Our study is area is large (~7 million acres) and the spatial resolution is fairly fine (5m). I'm running Pro 3.4.0 and can successfully train model on a smaller clipped out area (~700k acres) using only 6 explanatory variables for a smaller subset of ecozone types (n=18, where the total number is greater than 1% of total plots). However, the Predict Using AutoML errors out consistently after 2.5 hours and provides a generic Error 260204.
We are testing this modeling approach to see if it works better than our current approach and I have 10 more days to figure it out as I'm using a trial license to gain tool access.
Any help would be appreciated. These seems like a good application of the tools but maybe I'm missing something simple.
Attached images show result of trying to predict just 4 of the ecozones based on a model trained for those 4 ecozones only.
Thank you for reporting this.
Can you please share the following details:
1. How long did the Training tool run? If you have the tool output, please share that. 2. Can you try running the prediction on a single ecozone and see if that runs fine? For the purpose of testing, you can also try running it on the same data on which the training was done. 3. Can you please check if your rasters display name is different than actual raster name? If yes, try changing the display name to the actual name. (This is a workaround until you have the fix which has been made in the code recently)4. If the above step is not applicable or does not address your problem, would it be possible to share some sample data and trained model with us to replicate the issue?
Regards
Thank you for the quick responses Karthik - answers below:
attempting to predict 'ecozone' based on the other six variables in the file.
I could clip rasters to a smaller area, but I still wouldn't be able to attach those without exceeding upload limit.
@Ol_VUW Did you ever figure this out? I might be having the same issue.
Thank you for sharing the details. We would like to know more. Can you please reach out to me at sbanik@esri.com?
Thanks
Supratim
