Nate,A couple of suggestions:1. please check if the service is started (using ArcGIS Manager) and can be previewed.2. Clear REST cache (http://servername:8399/arcgis/rest/admin or the rest/admin endpoint where REST is deployed)
I'm also not able to log into the REST Admin even though my user name is part of the agsadmin group, so I can't clear the REST cache either. I suspect that if I can clear the REST cache then I might be good to go.
C_R_CI can't log on the the rest admin console with any account, be it local in the agsadmin group or the network admin account.
I'm getting a nearly identical error with AGS 10 but the .NET version on Windows Server 2008 R2. I've just installed AGS10 with a Standard Workgroup license and created a service in Manager. I can preview the service in Manager and browse to the REST catalog at http://servername/ArcGIS/rest/services/, where I can see my service name. But if I click the service link 'Ags10Test (MapServer)' in the catalog then it redirects to http://servername/ArcGIS/rest/services/Ags10Test/MapServer with the message 'Service 'Ags10Test' of type 'MapServer' does not exist or is inaccessible.'I can browse to the SOAP service at http://servername/ArcGIS/services/Ags10Test/MapServer?wsdl fine: I get the WSDL as expected.I'm also not able to log into the REST Admin even though my user name is part of the agsadmin group, so I can't clear the REST cache either. I suspect that if I can clear the REST cache then I might be good to go. I'm using IIS 7.5 on the GIS server, and it has 'Anonymous Auth' enabled for the ArcGIS\rest virtual directory.I turned GIS Server logging to verbose but nothing is getting logged either there or in the IIS logs that's of any use.
Přihlášení členové mohou přispívat, sledovat novinky a další. Jste tu noví? Zaregistrujte si účet zdarma.
