Adding related table records in arcgis pro?
Can't seem to be able to get this to work correctly.... Has anyone been succesful doing this at all?
Using latest ArcGIS Pro and either SDE or FGDB's.
Cheers
You are referring to these help topics?
Joins and Relates .... and
Add Relate tool in ArcToolbox
pretty well everything is now in ArcToolbox in Pro, so you might want to indicate if you are not using this approach and if you are, what isn't happening
Hi Dan,
I'm referring to basic user editing. i.e. I want to add a related record in a table already related to an existing point feature class in ArcGIS Pro. For example a company may have a technician visit a point once a month and every month that tech adds a related record as another visit done. Hope this makes sense.
You could use Collector for this as explained in this blog (from 2015): Related Tables – Exploring New Ways to use Collector for ArcGIS | ArcGIS Blog
Thanks Xander, I'm familiar with Collector workflows for in the field, however for an office environment we are wanting to do this in ArcGIS Pro only.
Similar idea but appending two identical hosted layers with related tables. ESRI support has filed it under BUG-000102178.
Hoping for a resolution as this is a fairly common workflow.
I know this is a very old thread, but since it took me forever to find out how this works, I'll post anyway.
To relate records from two tables that already have a relationship class defined, do this:
From the attributes window you can add new records to the related table by right clicking and selecting "Add New to Relationship". This will populate the new related table record with the parent record id value.
That's what that option does! Viola! Thanks for sharing.. Life in the GIS world I guess. We are blessed to have all this great software that is always expanding, improving so fast sometimes that I don't get a chance to absorb everything as it rolls out and I know that there are all these great functionalities that I just need to "discover". Like this one.
Cheers!
As of ArcGIS Pro 3.3.0 (and likely earlier versions as well), it is possible to add records on related tables via the Attributes editing tool (on Edit the ribbon). Select an existing geometry feature on the parent feature layer or create a new feature, open the 'Attributes' tool, underneath the selected parent feature's attributes you will find the related table; right-click add new record. Note, the related table needs to be in the map (you will see a warning exclamation mark symbol in the attribute tool if it is not).
Contributor please select solution. I just posted and then realized several others had already answered the question. Oops. Would be nice if latest replies showed first.
Přihlášení členové mohou přispívat, sledovat novinky a dělat další věci. Jste tu noví? Zaregistrujte si bezplatný účet.
