Hello,
I have a bunch of files that are poorly organized, some are baked into previous/old projects, some live in .gdb, some are shapefiles that are organized to different folders. I am working on an overhaul of our data management, to restart from a more organized place. I need to preserve the old data locations to not disrupt file paths for my old projects, which I am saving for the time being until everything is updated. I have a few questions if anyone can provide advice:
1- I understand that each new project creates a default .gdb for the project. That is fine with me, as long as none of the feature classes/data from the project autosaves in there. I want the project to pull from data that is preserved as MASTER copies. I want to avoid the problem of data being only accessible inside one project. If a project is deleted, does the default .gdb get deleted too?
2- Are .gdp tied to a specific project? Is it poor data management to have a new project pull from an existing .gdb?
I had originally thought I should create new MASTER versions (copied from the originals) of all the data, save them to organized folders within file explorer, and then pull those into each new project. However, it seems like there are a lot more tools that make using .gdb easier long term. Can I achieve the same result of saving a MASTER version of the data to a geodatabase that is standalone (not connected to a specific project)? My problem with this is that data saved to .gdb do not come up when searching within Microsoft File Explorer, which means if I am looking for the data in the future, I would have to know which specific .gdb to open. Is there a workaround to locating files within different .gdb?
Thank you for any input/help you may have. Most of my data is simple feature classes/feature datasets that contain point/line/polygon information.
-> Editing to add: Can I also include a readme file in the .gdb to have information for others to read? How would i save that to the .gdp?
