Is it possible to create an expression to get ArcSOCs in-use/used against each service on an ArcGIS Server Host. Can you please let me know how to achieve this?
Hi @NaveenK,Please review this blog, 5 Useful ArcGIS Server Analysis Elements in ArcGIS Monitor (please see element #3)Hope this helps,
@NaveenK , to add to @DerekLaw , note the difference between
Metrics reference—ArcGIS Monitor | Documentation
Process instances, which is the number of arcsoc.exe running at the collection time (e.g. every 1 min):
and
ArcGIS Service Instances used, which is an average over collection interval, e.g. 5 min.
It is expected these numbers will be different.
Thank you.
Hello Everyone,
I need guidance on ArcGIS Enterprise 11.1 capacity planning with Postgres RDS as the backend.
Scenario:
Services Published:
Data:
Application Functionalities:
Question:How many concurrent users can a single ArcGIS Server support under this setup?
Would appreciate any insights on capacity planning and optimization strategies.
Thanks in advance!
