Current version of ArcGIS Pro is 2.1.1. Are you sure you are working with a beta version? Have you tried using the latest version?
I am waiting for the installation. Why would the latitude numbers work out
correctly and the longitude are just whole numbers?
Steven M. Schwartz, L.S.
Cartographer/Land Surveyor/Geodesist
Contracting Officer's Representative (COR)
Geospatial Services Division
Bureau of Ocean Energy Management45600 Woodland Rd., VAM-LD
Sterling, VA 20166
Tel: 703.787.1239 | FAX: 703.787.1165
Steve.Schwartz@boem.gov <Steve.Schwartz@boem.gov>
*GIS maps and data: *
http://www.boem.gov/Oil-and-Gas-Energy-Program/Mapping-and-Data/Index.aspx
<http://www.boem.gov/Oil-and-Gas-Energy-Program/Mapping-and-Data/Index.aspx>
DOI <http://www.doi.gov/>* - *BOEM <http://www.boem.gov/> - Marine Cadastre
<http://marinecadastre.gov/default.aspx>
*Warning: This message is intended only for use of the individual or
entity to which it is addressed and may contain information that is
privileged or confidential and exempt from disclosure under applicable law.
If the reader of this message is not the intended recipient or the employee
or agent responsible for delivering this message to the intended recipient,
you are hereby notified that any dissemination, distribution, or copying of
this communication is strictly prohibited. If you have received this
communication in error, please notify the sender immediately by return
e-mail.*
I just did a test with 2.1.1 and all seems to work fine:
resulting in:
What settings, coordinate system are you using?
My data is WGS84 UTM 04N projected coordinate system - here is my settings
for Add Geometry Attributes:
Here is a partial of my results:
Can you verify that the output fields are of type Double?
I can - these fields are created when using the
tool, I didn't create them, nor did I edit them.
