Hello,
I have a polygon Z feature with many vertices and anthor feature of point Z type, Is there's any method using ArcPro to replace the Z values of the polygon vertices by the vertices of the point feature automatically?
You could submit an idea: https://community.esri.com/t5/arcgis-pro-ideas/idb-p/arcgis-pro-ideas
If you do submit an idea, it would help if you could link to it here so that I can follow it.
Can you describe the relationship between the points and the polygon vertices?
