Hi
Is there a way to set an attribute permanently to a number that is generated as a report?. The number in the report is calculated in a main CGA file, and the attributed that needs to have to same number is in a CGA file further down the stream.
No, it is not possible to use the values generated by reports when setting attribute values or anywhere else in the cga code. Reported values can only be seen in the Inspector or used in the Dashboard.
Using python you could
