I have an edit widget but would like to change the title of it. Below I have attached an image circling what I want to change. Thanks!
In experience builder, first click on the edit widget to bring up its properties pane, then you should be able to just click the title and type whatever you want here:
Thank you! I was also wondering if there was a way to change the 33 to a different title.
This should get you what you're looking for: https://community.esri.com/t5/arcgis-online-questions/change-default-field-displayed-in-map-viewer-edit/m-p/1261934#M50551
I have had the same issue. Wish it could be done in an easier way.
