Is there a way to add the Esri Web Stylx files loaded to the ArcGIS Pro Styles folder into the symbology selector in the Map Viewer? For use across the org?
There are many good styles that are available in the Pro/Portal/ArcGIS Online that would be awesome to utilize in the Map Viewer without having to create a .png from the style and upload to the symbology selector each time you want to use it.
