Dana,You can zoom to predefined scales via the "Zoom To" drop down on the ribbon. Zooming to user specified or arbitrary scales is unfortunately only possible via the API - which means you would need to develop an "Add-In" to do this. I have actually developed a prototype Add-In which offers this functionality: it's in the form of a Gallery Add-In which can be added to the ribbon via an Application Configuration - for example to appear on the Home tab in the Map group. I will investigate making the prototype a little more robust and posting it on our "Labs" area on ArcGIS.com (unsupported Add-Ins from the Explorer team). Alternatively feel free to try this yourself - take a look at the ZoomtoMapScale on the MapDisplay class: http://resources.esri.com/help/1200/arcgisexplorer/componenthelp/index.html#/_/000300000414000000/.
Dana,Thanks for suggestion. Unfortunately at this point I don't think this functionality is likely to be in 1500. One of the reasons it hasn't been in 900/1200 is that map scale isn't really relevant in 3D and traditionally ArcGIS Explorer has been a 3D application. However with the inclusion of 2D from 900 onwards, I agree, it would be a nice feature to have. Perhaps the scale value display / drop down / button could be disabled or hidden when in 3D mode?I'm just trying to decide how to handle the 3D situation in my Zoom to Map Scale Add-In before I post it. Current plan it to tilt the obersver view back to 90 degrees (looking directly downwards) then zoom to the specific scale. However in 3D it will always be an approximation. Alternatively I could jsut disable the Add-In while in 3D mode. Your feedback would be appreciated on this.RegardsMike
Dana,Apologies for the delay in posting this - I hope to have the Add-In hosted in the ArcGIS Explorer Labs group on ArcGIS.com shortly but for now I have simply posted the Add-In straight to ArcGIS.com: http://www.arcgis.com/home/item.html?id=dd68c3836cb24d6d9d5030f6837e61a2. Feel free to send any feedback on this Add-In to mbranscomb@esri.com.RegardsMike
This is a great add-in.
I'm glad I found it.
It's very very helpful.
The only thing better would have the scale in the bottom corner as you are zooming so can keep track of it when you are zooming in and out a lot. I see it's been mentioned and hopefully it will be available for newer versions.
Thanks and keep up the good work there at ESRI
