Is there a method available to query 3 or 4 feature services into a "LIVE" single table for use in an ArcGIS Online (AGOL) Dashboard? If not, are there any workarounds or alternative approaches currently available?
Thank you so much for your reply, Could you please help me to write the expression that query 3 or 4 feature services, and I will edit it accordingly.
Thanks in Advance
You could create a Data Expression that aggregates data from several services.
You would need to set a refresh interval to make it "live"
https://doc.arcgis.com/en/dashboards/latest/get-started/create-data-expressions.htm
Jill
