I made an aerial photography page for one site and the banner only shows up when editing, and not when published
In another site, when I click the home tab, everything reverts to an older state
This then undoes all the other pages, too
Is it possible you aren't the only person editing the page? If someone else had a older copy of the site open in their browser and clicked save, they'd be over-writing your changes. (I inadvertently did that to a colleague once; I felt so bad.)If you are the only one editing and the following steps do not work for you, I would open a Support issue.1. Change banner image in layout editor2. Save changes2. Preview draft (confirm it is to your liking or share with others for review)3. Return to editor4. Publish draft5. See banner updated on published (live) site
So the actual problem turned out to be that I thought I the publish button published the whole site, turns out it just publishes the page your currently on
Hi @ThomasGoodridge,It might be that your browser is caching the layout. You could try clearing the cache for your browser or opening the published site a private browsing window to see if the problem persists.
Other people are seeing the same things on there computer, too
Those steps worked, thank you!
