I cannot disable popups for certain layers in Experience Builder. They are disabled in Map viewer, but the popups are still enabled in Experience Builder. How can I disable the popups I don't want?
If I remember correctly, disabling in Map Viewer doesn't carry through to XB for some reason. You can turn them all off at the bottom of the Map widget > Content tab. See attached. If you still need to see popup for one layer on the map, I generally use the FeatureInfo widget to essentially dock the popup on the side. You can pick a layer from the map to show in the FeatureInfo widget.
@FOMELC01 Could you please help us better understand and provide more information on this? Were you referring to the map search tool pop-up control? Or map-click, or pop-up triggered by other widgets' selection?
