When adding a "double" field type in ArcGIS Pros Feature Class Wizard, please allow precision and scale to be defined if using an enterprise geodatabase.
For example: if I add a double field to an enterprise geodatabase dataset within the wizard, the precision and scale can not be defined, and this results in them being 38,8. In most of our use cases this far exceeds any precision and scale we'd use and bloats the table. If I want to alter the precision and scale, I have to manually do it through the database interface like SSMS.
