I'm trying to understand how the etc/hosts file works in conjunction with migrating to a new server using webgisdr. Is the only purpose to resolve URLs in the source backup to the target machine for the duration of the backup? Or is the information somehow used in the configuration of ArcGIS Enterprise when you install it? The documentation and various blogs indicate to set the etc/hosts file prior to installing ArcGIS Enterprise. I'm trying to understand if you can switch from machine names to using aliases in the migration process and how you would set up the etc/hosts file.
